I am working on door panels, noticed that one of the stock speakers was bad, went to the JY to get the only locally available replacement and it was worse than my bad speaker. My door panels were supposed to be done and I wanted to get something (yes rushing things, 1st mistake) so I went to the local stereo shop (2nd mistake?), talked to a guy who has been there forever and who I do actually trust. We did not discuss the intricacies of Volvo systems, just identified + and - on my OEM speaker. Anyway, found a nice pair of Alpine 6.5 inch component speakers SPS-610C, disassembled my OEM speakers / mounting standoffs and installed the new speakers. The fit is fine but now I'm not so sure that the sound is right.
I referred back to several forum posts and everything seems to indicate that Volvo used 8 ohm speakers wired in pairs so that the radio sees 4 ohms as most car head units, OEM or not, seem to expect. I think I follow that reasoning so I started second guessing myself and began shopping for 8 ohm 6.5 inch speakers. I do want to figure out frequency response of the OEM speakers to help identify the correct aftermarket 8 ohm 6.5 inch speaker. But then I looked again at one of the front door speakers I pulled:
So what the heck?! I thought Volvo speakers were 8 ohm? Not the pair I pulled from my front doors! So now I think ok, if I had 4 ohm speakers and installed 4 ohm speakers I'm golden right? Well something still doesn't seem quite right. It sounds too tinny, almost like the bass is disconnected from the rest of the audio, just not right. There is still bass coming from the back doors but those by themselves do not make enough bass to sound correct in the front seats. And I don't mean I am trying to get everyone around me to hear that I am rockin' the Volvo. Regardless of the type of music, at anything above really low volumes, it seems clear that there is not enough bass.
Possibilities:
1) I have replacement speakers with a wildly different frequency response range
2) Maybe the crossover on the new speaker should be removed. I don't think so and I hope not, I don't think it can be without destroying the speaker. From Crutchfield: "The Alpine SPS-610C features low-pass crossovers attached to each woofer's input terminal and high-pass crossovers in-line with the tweeters' speaker wires." My thinking here is that perhaps the HU is only putting out the frequencies that should be going to that speaker (internal crossover in the HU basically so the speaker doesn't need a crossover)
3) The Alpines came in a set of two pairs, two 6.5 inch speakers and two tweeters. The tweeters are designed to hang off of the 6.5s, not wired directly to the radio. When I bought them I figured the 6.5s are basically what I am replacing and I just will not use the tweeters. Well if the box says the speakers are 4 ohm (doesn't clearly say each), maybe they are 4 ohms when wired as a pair. In other words, maybe the Alpine 6.5s alone are not 4 ohm.
Here is what I plan to do for now:
Try to research if the Alpine 6.5 inch speakers are 4 ohm by themselves or only when wired with the tweeters
Try to find out if having two crossovers messes things up (if the radio has this function built in alongside a speaker mounted crossover)
Try to identify the frequency response of the OEM speaker
See if I can figure out how to test for myself with a multimeter, what the ohm ratings of speakers are. I know they may not be exact but maybe they should be approximate.
But my single main question, why is this speaker clearly labeled 4 ohm when everyone says Volvo speakers are 8 ohm?
This thread has more pictures
