Hi folks
There's such a mish mash of info re which models have mechanical or hydraulic timing belt tensioners so I just grubbed in and pulled my cover to check what my wagon has..... and indeed I do have a hydraulic tensioner on my Australian delivered V70 AWD (build date of 7/97).
Funnily enough my workshop manual purports to cover models from 1996 - 2000 however doesn't even mention a hydraulic tensioner!???
I'm sure the procedure for doing the cambelt change has been discussed before however I haven't been able to track it down by searching. Could I trouble someone to please point me in the right direction re this job?
Cheers in advance
1998 V70 Cambelt change with hydraulic tensioner
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Over here we call them timing belts
This is one of the best write-ups on the subject:
https://www.matthewsvolvosite.com/forums ... =1&t=19831
It features a turbo engine so some of the parts may differ, but the steps should be the same.
Take a peek at this page and you'll see plenty of other help:
https://www.matthewsvolvosite.com/forums ... =1&t=47793
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Has thanked: 312 times
- Been thanked: 818 times
This is a classic link for timing belt DIY, been up for like 8 years, simple, well illustrated and crystal clear:
http://volvospeed.com/volvo_repairs_how ... hange.html
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It's the same as the 850. Turbo or not it's the same. Easy to follow.
As for the tensioner, compress it with a clamp very slowly, maybe 1/2 turn every 5 minutes. If it leaks any fluid, change it.
precopster
- Year and Model: Lots
- Been thanked: 128 times
If you need a hand the first time around, and you're in my area (Northern suburbs) more than happy to lend a hand with your cambe...I mean timing belt. We can exchange some ideas about the maintenance of these beasts and share a common interest. PM me if that appeals.
- 3082 Views
Last post by turbozed
- 14 Replies
- 4030 Views
Last post by Cees Klumper
- 1608 Views
Last post by precopster
- 5177 Views
Last post by rspi
- 887 Views
Last post by erikv11
