96 850 Turbo- Still having Idle problems, suggestions?
mlance2
Year and Model: 850 Turbo 1996
Post by mlance2 »
I have been dealing with this problem for quite some time now. Basically when I start the car the idle fluctuates between 700-1200 rpms, and throttles itself back and forth. While in Park or Neutral it will continue to ide back and forth, but once I have put it in gear (reverse or drive), the rpms will decrease (and die) if gas is not applied. Here is a list of repairs I have done so far:
Distributor cap
Roto Button
Spark Plugs
Ignition Coil
MAF sensor
Throttle Positioning Sensor
Three vacuum hoses labed yellow, red and blue which are attached to the air fliter container
My check engine light is now off and the idling problem has improved, but there is still the constant fluctuation of rpm and occasional dying. Any suggestions or solutions? I have read these might be possible solutions: Idle air control valve, Fuel Regulator Sensor, or possibily a cracked or broken intercooler line from under the car.
Any ideas or suggestions would be greatly appreciated
Thanks Guys
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
No codes?
Also -> Amazon link
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
What codes were on before with the check engine light?
I would definitely clean the idle control valve and throttle body if there are no longer any codes.
'98 S70 T5
2016 Chevy Cruze Premier
mlance2
Post by mlance2 »
So check engine light did come on, which showed codes p1310 and p0300 and I'm fairly certain those are for misfiring for the cylinders. I cleared them this am and they have yet to show back up. I did not replace the spark plug ignition wires, I ordered them and should receive them tomorrow or thursday at the latest. I believe this might be a solution to the idle which now is less prevalent but still noticeable at times. Thoughts?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
Question: at highway speeds, does it straighten out and run normally?
If so, I would think this might eliminate plug wires, since if they were shorting, they'd most likely do so at any rpm, under load or not. What do you think?
mlance2
Post by mlance2 »
The idling is drastically improved from where it was, but it is still there, while yes the car runs fine at highway speeds, you still feel the misfire in while driving every so often, which is to say you feel it miss and then catch it self even if it is ever so slight, i think the wires may still work since it is the only thing I didn't replace in the sequence from plugs to coil. The only other thing is to clean the idle air control valve which may be the cause as well
JimBee
Post by JimBee »
I asked about the highway performance b/c I picked up a '96 turbo last August that has a similar condition—only wildly erratic when idling cold. I drove it on a 70 mile highway trip and warmed up, it seemed pretty normal. It's been sitting since, but I'll be back playing with it soon. I'm wondering if it's a vacuum leak. I plan to replace the elbows on the vac lines and the throttle body gasket. I've done most of things you listed and the problem persists. Keeping it running while it was surging and dying must have flooded the cylinders b/c my cat go really hot. So I also plan to clean the injectors, replace their seals and maybe have them checked if I can find a shop that does that.
Someone posted a couple of months ago about pouring paint thinner in the gas tank and letting it run through the engine to clean things up. There's a UTube video posted by a mechanic who says he's been doing it for years. I'm going to post a question to the group about it.
steve850
Year and Model: XC70, 2004 and 2010
Been thanked: 3 times
Post by steve850 »
The paint thinner is for the CAt. New wires and clean up the throttle body.
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
Sean-E-Boy
Year and Model: 1995 850 2.3T Wagon
Post by Sean-E-Boy »
1. Check the vacuum line connection on the left of the intake manifold.
2. Check/test the EVAP system.
On my 850, disconnected vacuum line at left side of the intake manifold caused rough idle and rough low end acceleration as well as the misfire codes.
Also, broken lines on both sides of the fuel tank roll-over valve resulted in spontaneous stalling (sometimes 2 or 3 times a day, other times a week or more between stalls). What's worse, A-2 never logged a trouble code for the EVAP, only discovered it after failing that portion of the smog test.
