Advice needed on axle removal - 1998 V70 Auto
PaulYork
Year and Model: 1998 V70 SE TDI Auto
Post by PaulYork »
Hi new to this forum so forgive me if this is in the wrong section.
I am in the UK and have a 1998 V70 Automatic (right hand drive)and need to change the right side CV boots.
I'm confident I can do the job but having looked at the various tutorials unless I'm missing something or being a bit stupid, my question is, before removing the drive shaft do I need to drain any oil and if so what?
Many thanks in advance for any help.
Biggest problem we have in the UK because there are not enough of this model V70 on the road here there are no repair/workshop manuals in publication, the usual publishers did not think it economical to produce one. :cry:
Reason: Edited title for clarity.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
No need to drain anything. You may get a tiny bit of transmission fluid when you pull the shaft from the transmission.
Also -> Amazon link
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Try to grab a VADIS or even a Haynes manual from E-bay/Amazon, better than nothing. Also, look around about pulling the axle, one thing I think I saw was the use of a "special" tool, essentially something that looked a little like the end of a wrecking bar to help pop the axle out of the transmission without overly stretching the boots/joints.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
PaulYork
Post by PaulYork »
matthew1 wrote:No need to drain anything. You may get a tiny bit of transmission fluid when you pull the shaft from the transmission.
Many thanks :D , without your help(to be on the safe side)I would have drained the trans fluid .
PaulYork
Post by PaulYork »
rmmagow wrote:Try to grab a VADIS or even a Haynes manual from E-bay/Amazon, better than nothing. Also, look around about pulling the axle, one thing I think I saw was the use of a "special" tool, essentially something that looked a little like the end of a wrecking bar to help pop the axle out of the transmission without overly stretching the boots/joints.
Sure there are Petrol V70 manuals about but damned if I can find a diesel mine is a 1998 SE TDI Auto, which is why finding this website/forum has been a godsend. :D
The boots are what I have to change so the whole shaft has to come out.
rmmagow
Post by rmmagow »
Wish we could get the diesel here! My other daily drive is an old 85 Mercedes 300D Turbo, 30+ mpg all the time.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
No need on the RH side. No circlip on that one.
Just remember to pull the pillow block,
( two 12 mm bolts ) and it'll slide right out.
PaulYork
Post by PaulYork »
Got the shaft out at last.
Everything went OK(as per the tutorial) until I got to pulling the shaft itself out, it came so far and then refused to come all the way. I cut the inner boot away cleaned all the grease off but could see no reason why it wouldn't budge, eventually put the drive in neutral turned, pulled, twisted, swore a lot then suddenly it popped out. It just seemed as if one of the lugs on the cv joint did not want to come out. Just hope I can get it back in a bit easier.
Free2drive!
Year and Model: 2007 XC90
Post by Free2drive! »
It should just pop in!
It will be prudent to replace the axle seals to stop fluid escaping and dirt getting in.
Let us know how you get on.
Matt
PaulYork
Post by PaulYork »
rmmagow wrote:Wish we could get the diesel here! My other daily drive is an old 85 Mercedes 300D Turbo, 30+ mpg all the time.
If you look at my avatar you can see my daily drive, with a half race 2.1 pinto engine(petrol) and 38 DGAS weber carbs I can if I'm lucky with the traffic coax 20mpg out of it :roll:
