Thanks,
I'm looking into the Alldata subscription now!
Clutch replacement
- NitroVolvo
- Year and Model: 1998 S70 T5 SE
Re: Clutch replacement
'98 S70 T5M SE (Silver Surfer)
'98 S70 T5 SE (Black Jacques Shellac)
Retired: '91 740 TM (Silver Fox)
Retired: '89 740 (Grey Ghost)
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1338 times
I’ll add this on this job.
It’s about 10 hours including all those other things that you do in there. I broke it up over two weekends and two days each weekend for 2-3 hours.
First prep, struts off prep car for engine drop
Second. Subframe drop engine drop, engine trans separation.
Third rework clutch , reconnect engine / transmission
Fourth Finalise and clean up
Link To Volvo Glossary
I am going to add to this.
When I did my P2, I found a hybrid of the Dual mass Flywheel and non-self adjusting clutch. This was stock build from the Ghent factory.
So, I would hold off ordering parts until you get the thing apart and see what parts you have
- NitroVolvo
Does the Alldata service provide info on what else I can be doing while I have everything out?
It has procedures for most everything but you have to come up with the list yourself
Clutch
Pressure plate
Flywheel resurfacing..
Rear enginecoil seal
Transmission oil seal
Release bearing
Clutch
Pressure plate
Release bearing
