No Lowbeams on my 240
Slumbo555
- Year and Model: '91 240, '99 S70 GLT
My Lowbeams stopped working on my '91 240 about a week ago. The highs still work fine. I had the same issue with my S70 a few years back, and the problem was the relay. I assumed the same for this car, so I ordered a new one from ipd. I installed it today and it's still a no-go. I pulled a bulb out and checked it out and it looked fine to me. I'm not sure what else could be the problem. The relay I replaced is the "step" relay under the hood. It's my understanding that the main relay in the dash is just a master on/off for the lights and wouldn't have an affect on the beam setting. Does anyone have advice on what to check next? Thanks for any input.
-Slumbo
1991 240, 209k
1999 S70 GLT, 140k
1991 240, 209k
1999 S70 GLT, 140k
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have you tried swapping bulbs left to right, right to left? Sometimes a good looking bulb can still be out. If it is truly the bulb a new rely will not help.
Slumbo555
As far as I know it is working. When you switch from low to high beams, and vice versa, there is a click at the relay under the hood. I assume that means the switch is working fine. I have some extra headlights so I'll try them out to make sure it isn't a light issue, but I'm fairly certain it isn't.
-Slumbo
1991 240, 209k
1999 S70 GLT, 140k
1991 240, 209k
1999 S70 GLT, 140k
Bigblue
- Year and Model: 2001 XC70, 1991 740
The high beams and the low beams are on separate fuses...These cartridge type fuses are prone to a whitish corrosion...If they are not blown, try spinning them in the holder to clean them up...
- MoVolvos
Did you go through all the fuses just in case it is wired to another subsystem rather than just the lights. I think the Trunk Open light in the dash is related to the interior lighting to which I shorted (if I remember correctly).
Slumbo555
Problem solved! It was the bulb integrity sensor. I had read that these things commonly fail after about 20 yrs or so, and can cause several problems with your various lighting circuits. Evidently the Lowbeams go through this sensor, but the highbeams do not, so that pretty well explains the symptoms. Got a new one off eBay for about $35 plus shipping, and it's an easy fix. Hopefully this can help someone in the future. Thanks for the input everyone!
-Slumbo
1991 240, 209k
1999 S70 GLT, 140k
1991 240, 209k
1999 S70 GLT, 140k
- 950 Views
Last post by maverill
- 1290 Views
Last post by ducttapeandzipties
- 1060 Views
Last post by 93Regina
- 1737 Views
Last post by Freestate
- 3211 Views
Last post by woc2
