1983 240 Manual Transmission Overdrive Intermittent
The overdrive works intermittently when the OD button is pushed. When it works, the green OD light comes on, and the overdrive engages. It also deselects fine. OD does not work each time OD button is pressed. OD switch and relay changed out. Wiring repaired where insulation deteriorated. Wiring looks good. What else could be wrong?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The attached is from a Volvo publication:
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Bigblue
- Year and Model: 2001 XC70, 1991 740
A common failure in these cars is the wiring for the OD switch at the base of the shifter...The wires fatigue and break inside the insulation so that it is not evident to the naked eye...Pull the shifter boot up and away from the tunnel and you will see the two wires coming out of the bottom of the stick and routing down through the floor...If they are broken, you will be able to feel it for lack of stiffness at one point in the wire, or wires...If so, a splice is in order...
Voila! I checked the OD switch wire at he base of the stick and found the problem. After splicing in three new wires which were obviously bad, I assumed the OD harness was okay because it looked good on the exterior. Lo and behold, when I tested the OD and it worked, I then moved the wire harness a little. The OD stopped working. Very insidious. Ordered a new harness from IPD. They provide an excellent attachment on how to replace it. In the process, learned that a new solenoid is a difficult part to find. Thanks for all your help!
- billofdurham
Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 24 Replies
- 7133 Views
Last post by 93Regina
- 7389 Views
Last post by 30volvos
- 878 Views
Last post by sergitin32
- 1484 Views
- 1388 Views
Last post by lummert
