Hey everyone,
I've been having a strange issue with my S70. The car will spin but not start until I physically go and disconnect the battery and then reconnect it after about ten seconds.
It is very strange because If I put my key in the "I" or "II" position, disconnect/reconnect the battery the car will start. However, if I do the above then take the key out and put it back in, the car will crank but not start.
Any idea what could be causing this?
Edit: The car runs perfect once I start it.
2000 S70 Cranks but won't start unless...
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
When it is in non start mode, pull your codes. Also in non start mode, unplug the MAF before attempting to crank.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
I have tried pulling the codes when it is in no-start mode and got nothing. When I leave work today I will try unplugging the MAF before cranking and post back however, I just replaced my MAF a month or so ago.
Update:
1) No codes while in "no-start" mode.
2) Car will not start while in "no-start" regardless of the MAF being unplugged or plugged in.
3) Oddly if I unplug the MAF while the car is running I am able to start the car right up after plugging it back in as long as I keep the key in the II position.
- 4434 Views
- 4309 Views
Last post by ellis2311
- 2029 Views
Last post by rspi
- 11 Replies
- 4157 Views
Last post by dubsetter
- 4230 Views
Last post by BestNana1485129
