Hi Guys,
My beloved 96 Volvo 850 GLT speedometer has stopped working.
I am not too sure where to start with the troubleshooting. Some months ago (in Nov 11) I replaced the small gear for the odometer. Everything has been working fine...and now the speedo is acting up.
Any idea where to start? Speed sensor (where is it located?) or Contact not making at the cluster panel or something else?
Any help would be appreciated thanks,
jmmxc
SpeedoMeter stops working, Need some help..
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Is the ABS light on?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Check for codes. Usually that means the ABS module is bad.
petek153
- Year and Model: 1992 940T
Had a problem with mine also check out this link to see some of the checks I did and a couple links for trobleshooting.The fix for mine was a poor solder joint on the cluster.
https://www.matthewsvolvosite.com/forums ... =1&t=42486
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
jmmxc
- Year and Model: Volvo 850, 1996
Sorry for the delayed response...
Yes my ABS has been disabled for about 10 yrs now. Never has a probleme with the speedo.
I have not had a chance to do a diagnosis due to extra workload at my job.
Will see about tomorrow...
In any case if you guys think of some thing that can help please do not hesitate to opine.
Thanks.
jmmxc.
Thanks.
jmmxc.
Matty Moo
Disabled as in it quit working and you never fixed it, or you did something to disable it intentionally?jmmxc wrote:Sorry for the delayed response...
That pretty much narrows it down for the most part. If you want to take the time you can test the sensors, but rolling for ten years with a bad module basically answers the question.
2000 s70 GLT
2014 Ram
Laird_Scooby
- Year and Model: 740 GLE estate, 1989
Hi,
i've just done some research (got similar problems with mine) on this on another Volvo forum in the UK and found this link to be very informative. It covers most models and it seems the major cause of any instrument, gauge or warning light trouble tends to be associated with the flexible printed circuit panel and the soldered joints to it on the back of the instrument cluster.
I'm hoping re-soldering the joints will cure the problems i have as over here in the UK, if the ABS warning light is on when it shouldn't be then it won't pass the MoT (annual roadworthiness test) so would probably end up as scrap.
Hope that link helps!
Cheers,
Dave
1989 Volvo 740 GLE auto estate
1994 Rover Sterling 827 auto saloon (that's a Sterling 827 to members the "wrong" side of the pond!
Dave
jmmxc
No, the ABS became defective as is the case for most people on this forum, after a few years. I attempted the fix for the module. That works for some months but it quit again. So I never bother fixing it as it looks like there may be issues with the cable going deep inside the ABS pump (insulation on cable and what not)...Not having ABS has not affected my driving, I got used to it (I supposeDisabled as in it quit working and you never fixed it, or you did something to disable it intentionally?
I believe I had read somewhere that ABS problems affects speedometer function starting with the '97 model, not the 96. Maybe you guys can confirm that.but rolling for ten years with a bad module basically answers the question.
I think it is more likely a problem with contacts like the link explains. Recall that that I took the cluster apart around last Nov. to replace some bulbs and the small odometer gear...i've just done some research (got similar problems with mine) on this on another Volvo forum in the UK and found this link to be very informative.
Other day I banged on the dashboard a few times and that got it going... again.
I think I need to take it apart one more time and make sure the solder joints, pins mating with the contacts are OK.
I will you guys posted on my progress, waiting for non rainy day w/o thunderstorms to check it.
Thanks for all your inputs.
jmmxc
jpeisker
- Year and Model: Two 1997 850 NAs
One other thing to check is your ignition switch. I have a '97 model 850 with a flaky intermittent ignition switch which causes various symptoms (no speedo, can't shift out of park, ABS light, no headlights or turn signals). Wiggling the key makes all these go away and the speedometer starts working again. I'll be replacing this switch soon.
Could be that while banging on the instrument cluster you jiggled the key or bumped the steering column when you made the odo work that one time. Flaky ignition switch can be sensitive to vibration like that.
Ignition switch is a relatively easy replacement on this model and not very expensive.
Let us know if you sort this out, whatever it turns out to be.
I have two 850s and both have had the ABS controller fail (solder joints). With the ABS failed or even removed I never had a speedometer failure, so I don't understand why people say there is a connection between speedo and ABS. I believe the electronic version of the odometer is tied to the ABS controller, but no the mechanical odo.
Jim
Jim
Laird_Scooby
Interesting about the ignition switch Jim - it had crossed my mind on mine (1989 740 GLE).
Not sure what the arrangement is on later models but the speedo sensor (mounted on the diff) also doubles as the rear ABS sensor on mine (no separate sensors for each rear wheel - strange arrangement IMHO!) so it could be Volvo used the same arrangement for later cars?
Cheers,
Dave
Dave
- 13 Replies
- 7284 Views
Last post by esl_97_850_T5
- 1090 Views
Last post by 1990Volvo740
- 2828 Views
Last post by NYVolvo1994
- 1484 Views
Last post by chrism
- 511 Views
Last post by Rorgan
