** sold ** 2003 XC90 T6 AWD ** sold **
Locked
gshadow325
Post by gshadow325 »
The time has come to sell my 2003 XC90 T6. A 2005 V70R has replaced it as a daily driver. This XC90 has served me well. It has a updated new(remanufactured OEM) Volvo tranny installed with 30k on it. There are reciepts to show that work was done. You can click on the link in my signature to see the extensive maintainance and modifications.
Cliff notes:
03 X90 AWD T6 Premium package, third row. rear air, dvd overhead, 169,000, New trans and rear main seal @ 137k.
$9750 as is
Minus Airhorn system, Dension GW500, Remote starter/Alarm system, Roof Rack system, and some other mods. $8000
Listed below is service records i have on a excel spreadsheet.
This is with PEGS, it will come with the OEM atlantis wheels also painted black
Service Records
Vehicle Date Time Odometer Reading Distance Unit Services Total Cost Location Payment Tags Notes
Xc90 5/9/2012 15:32 168,874 mi Rotate Tires, Tire Pressure $0.00 Check brakes good
Xc90 5/6/2012 18:02 168,866 mi Cabin Air Filter, Oil Filter, Engine Oil $80.00
Xc90 3/4/2012 14:24 166,061 mi Engine Oil, Oil Filter $80.00 Me 5quarts royal purple, two valvoline Mann oil filter
Xc90 3/1/2012 7:17 165,955 mi Brakes Front, Lights, Tire Pressure, Brakes Rear $0.00
Xc90 ######## 17:08 165,954 mi Rotate Tires $0.00 Ks Left to right and balanced. Left rear has plug in tire
Xc90 1/8/2012 18:44 163,544 mi Engine Oil, Oil Filter, Rotate Tires $80.00 Me Check front and rare pads
Xc90 ######## 10:33 161,047 mi Engine Oil, Oil Filter, Rotate Tires $80.00
Xc90 ######## 17:36 160,280 mi Body/Chassis $55.00 Me Rear driver outer door handle latch
Xc90 ######## 11:37 158,415 mi Spark Plugs $300.00 Oem tensioner pulley $90 labor $170 and one gallon coolant
Xc90 8/8/2011 16:45 158,355 mi Rotate Tires $0.00 Balanced tires, all 4 tires. No unusual tire wear.
Xc90 8/7/2011 9:56 158,346 mi Engine Oil, Oil Filter $80.00
Xc90 ######## 9:54 155,000 mi New Tires, Cabin Air Filter $500.00 Nitro neo gen
Xc90 ######## 9:53 154,539 mi Engine Oil, Engine Antifreeze, Oil Filter $135.00 New oil filter housing
Xc90 4/8/2011 9:52 153,355 mi Power Steering Fluid $35.00
Xc90 4/7/2011 9:50 153,350 mi Steering System $575.00 New steering rack used one from erie,
Xc90 4/3/2011 9:49 153,150 mi Suspension System $35.00 New left inner tie rod
Xc90 ######## 10:48 152,175 mi Engine Oil, Oil Filter, Body/Chassis $425.00 New oxygen sensors 3 of them
Xc90 ######## 10:46 151,000 mi Brakes Rear $60.00 new rear rotors
Xc90 ######## 10:44 150,780 mi Brakes Front, Brake Fluid, Cabin Air Filter $325.00 Ss lines, dealer pads, new front brake rotors, fluid changed
Xc90 ######## 10:42 150,025 mi Engine Oil, Oil Filter, Battery $330.00 Painter wheels black
Xc90 ######## 10:36 149,875 mi Brake Fluid $200.00 Brake booster 53-3115, brake fluid
Xc90 ######## 10:34 149,600 mi Battery, Belts $250.00 Excel alt 160 amp, dealer acc belt,
Xc90 ######## 9:07 148,500 mi Body/Chassis $335.00 Both front axles new from fcp groton
Xc90 ######## 9:30 148,000 mi Body/Chassis, Differential Fluid, Wheel Alignment $850.00 Rear ipd camber bushings, haldex oil, awd pressure sensor, haldex pump
Xc90 ######## 9:29 147,950 mi Windshield Wipers $45.00 Rear wiper,front left away bar end link
Xc90 ######## 9:27 147,750 mi Brakes Front, Air Filter, Suspension System, Wheel Alignment, Fuel Filter, Windshield Wipers, Windshield Washer Fluid ######## Upper ipd mount, upper turbo hose, inner tie rods both, hr springs, hr rear struts,
Xc90 ######## 9:24 145,750 mi Exhaust System ######## Reverse hid, roof rack, load bars, vent visors, oil cap gasket, magnetic drain plug,
Xc90 ######## 9:22 145,350 mi Body/Chassis, Engine Oil, Oil Filter, Suspension System $800.00 Left and right control arms, left and right ball joint, new headlamps, 6k low beam hid, gas door hinge
Vehicle is price to sell, and the only reason I am selling it is because i have no need for it. 3 cars one driver.
1998 Olive Green V70 T5 Manual - 155k Awesome car
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded
2001 Nautic Blue C70 T5 Manual - 92k Not stock at all
gshadow325
sold please close thread
Locked
