hi
i would like to know if someone ever replaced a clutch from a 1994 850 turbo manual. how hard is it and if there is any steps i should take.
it would be also appreciated to get some info about the clutch. someone told me the volvo clutch is assembled with rivets with the pressure plate and fly wheel, is that true?
thank you
Manual transmission help
dpauto.com
- Year and Model:
850 clutch assembly (kit) comes with 3 SEPARATE components, throwout bearing, pressure plate, and clutch disk. Flywheel should be resurfaced. Don't forget to replace the engine rear main seal while trans. is out. The job is not easy if you don't have a lift and special tools to hold the engine in place. Lets put it this way, it is not a job for an average Joe.
Regards,
Dave
Regards,
Dave
ASE - VOLVO Master Technician
dpauto.com
- Year and Model:
Rear main seal = rear crankshaft sealAnonymous wrote:what the rear main seal seals? coolant?
thanks for the help btw
Regards,
Dave
- 1360 Views
Last post by CEBirnley
- 19 Replies
- 3701 Views
Last post by precopster
- 29 Replies
- 6679 Views
Last post by E Showell
- 777 Views
- 15 Replies
- 24743 Views
Last post by amblerman
