Hi everyone
I need some help on finding where does the hose with the sensor located on the turbo inlet pipe goes.
i just finish doing a installing a tranny on a 01 s40 and i just can figure out where that hose goes to
thanks in advance.
Turbo inlet pipe hose location
Are you talking about the mass air flow sensor or the hose that comes from your PVC system. Does it have two hoses? One big one and one small one. That's your PVC hoses. They plug into the solenoid right next to the turbo inlet and don't forget there is also a electrical connection that also plugs into the solenoid. The maf has just a plug in electrical connector and it plugs in just after the air box in the maf housing. I'm not sure if this applies to you since I have an 850 but these car are very similar.
95 850 T5-R rip kit,18t,ipd strut brace,slotted rotors,cone filter with heat shield, boost controller and boost gauge,cat delete and high flow muffler,horns relocated
- 482 Views
Last post by Goupil
- 1878 Views
Last post by rspi
- 1956 Views
Last post by SonicAdventure
- 5145 Views
Last post by darrylrobert
- 577 Views
Last post by rocky_mtn_man
