Diagnostic Socket Weird Problem, opinion appreciated
petax
Year and Model: 850 T-5R 1995
Post by petax »
Hi
An 850 T5R, I have been counting the little flashing light on the diagnistic socket, under the bonnet.
Great tool, saves the need for a computer with serial bus etc, as required for BMWs.
I have been searching this forum looking for an explanation as to why some sockets in the diagnostic socket pins are not functional. On close inspection two of the sockets have no connection wire, nor the expected metal connections inside.
It appears that they were never there, I see no clipped wires or anything like that. I was worrying that the dealer I bought the car from had been even more unscrupulous than I thought, and has some how isolated the error codes from the turbo, ECU and other essential engine parts, to pull the wool over my eyes.
That is A5 TCU (Transmission Control), A6 Ignition System, neither appear to have ever been connected, and are certainly not now.
Before I start accusing the dealer of fraud, can anyone tell me if this is to be expected. Is there something I should be aware of? Anyone with experience of this, I appeal to you for information.
Does anyone know, should those sockets work, if not, how does one check the turbo and engine codes?
Thanks in advance.
1995 Black 850 T-5R Saloon 210,000 kms
jenkinskg
Year and Model: 04 c70 hpt 98 s70 xc
Has thanked: 1 time
Post by jenkinskg »
I would get a schematic and see where each pin come from.
Car with an ECU and no OBD2 is a tough nut to crack.
I had an old saab years ago, only way to tell if ECU was dead was get another ECU
good luck
2004 c70 2.3HPT, s60 2.5T
jenkinskg
Has thanked: 1 time
Post by jenkinskg »
only 4 or so connections are needed, keep in mind a computer on a network on needs 4 2 transmit 2 rec
the other 4 just shield the signals
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
A1 works in place of A5. In fact, there are zero codes for A5 listed. https://www.matthewsvolvosite.com/read-codes-volvo-850
Not sure about A6.
85 GLH, 367 whp
00 Insight, 72 mpg
