96 850 Wagon...Can anyone tell me what this part is?
VolvoJoe96
Year and Model: 850 Wagon GLT, 1996
Post by VolvoJoe96 »
I recently took apart and cleaned up my pnp switch in hopes that it would clear up my up arrow issue and the shifting (or the lack thereof) issues I was having. While getting into things I found this part with the wire cut in half or heat damaged. I have searched online and have made a couple of trips to the auto part store, I have yet to find out what this part is. Attached you can see the part.. and where it came from.
Thanks Everyone!
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I think this is it?
http://eeuroparts.com/Parts/PartDetail. ... mNumber=11
VolvoJoe96
BKM,
Thanks for the quick reply, this was my first guess, but the bottom appears slightly different. It doesn't have the small circular metal piece. Also being a novice I wasn't sure where the crankshaft sensor went. Do you know if its the same sensor with a new look?
Thanks!
Joe
MoVolvos
Post by MoVolvos »
VolvoJoe96 wrote:BKM,
Thanks!
Joe
I went to Rock Auto as they usually carry several brands. Two looks more like yours but the 3rd does not. I am assuming that is a Stock (Generic) Photo so not to worry. If your car starts the part is OK and should you need to purchase one I think you should receive the correct part.
http://www.rockauto.com/catalog/raframe ... 06-2461556
Been thanked: 818 times
Post by erikv11 »
100% for sure that is the crank sensor.
I agree with BKM that you don't need to replace it if the car is starting OK. But if you hit a no-start condition, that is the first place I would check. Maybe pick up a spare from a junkyard.
VolvoJoe96
Erik and BKM, Thanks for the replies. I just unpluged that sensor, and the car still started fine and ran at an idle. I have been having shifting problems however and took apart and cleaned up the PNP switch, afterwards I took the car out for a test drive and it ran great for about the first 11 miles, then I think it went into limp mode and just got me home. I redid the PNP switch figuring I had got it but then lost it somewhere during the drive, this is when I found this sensor with the one wire cut or heat damaged. I repaired the wire as best I could and now have no gears at all. You can hear it go into gear and it feels as though it R or D, however when you press on the acclerator it acts as though it isn't fully engaged.
VolvoJoe96
Just thought I would give an update. I have learned that it is the RPM/Engine Speed Sensor. Now its just a matter of finding one. Thanks Erik and DKM for your help!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
LOL, yea, when I seen the first photo I knew it was a speed sensor. Cars prior to '96 don't have that one their transmissions.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Not the crank sensor or RPM/engine speed sensor. That sensor is on a bracket connected to the block. It is the vehicle speed sensor for the transmission. It connects to the TCM.
The part is the same for 96-98 year models of 850 and s/v/c70.
I have one of those in the bag but I just looked and I can't find it to give the part number.
