93 850 No Start, No fuel pressure
wa98146
Year and Model: 1993 850
Post by wa98146 »
Hi,
My 93 850 will not start. No fuel pressure. Did jumper the #15 & #87 fuel pump relay socket, but still no fuel pressure. Is it certain that its the fuel pump? what else could it be? Please help.
It has spark and cranks, but no start. pinched schrader valve, but only a couple drops of fuel dripped out. The fuel pump seems to be quite expensive... Thanks.
Details: It was driving fine on the freeway, and arrived at my destination, parked and went shopping. When I came out and about to leave, the car started, but rough idle, give gas no go - no power and stalled. It was a hot day - car temperature shows 31C outside. Tried to start again and couldn't. Pushed the car, parked overnight. Checked DTC A6 214 & 314. Cleared it, and has been 111 since then.
Next day go back pick up the car, tried to start at first, but it would not. DTC A2 & A6 111. Later tried again and it started, drove it to almost home went to the post office, came back out, it would not start again. Towed it. Now DTC A2 & A6 still 111.
Please help! Thanks!
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Go to O'Reilly's or Autozone and rent a fuel pressure guage. Attach it to the shraeder valve and when you turn the key to position II you should have about 43lbs of pressure. If not, then it is either the pump or the fuse (little 1 in the fuse box, forgot what number) or relay with the number 103 stamped on it. Let me know what you find out and take it from there.
Edwin
wa98146
Post by wa98146 »
Hi shaker_chi,
Thanks for your reply. I pushed on the schrader valve with a screw driver (without gauge) and there was only two drops of fuel came out, its obvious there is no fuel pressure. Also jumped the #103 fuel pump relay #15 & #87 socket, but still no fuel pressure. Also, I don't hear the usual "spinning sound" that I used to hear inside the cabin when key's in pos. II. So I am guessing it's the fuel pump.
My question is could it be other things beside the fuel pump? Also, why is there a huge difference in price for the fuel pump assembly (~$400) & the fuel pump insert (~$80)? Could someone tell me the difference? What will I need?
Thanks in advance!
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
When was the last time you changed your fuel filter - could be clogged.
wa98146
Post by wa98146 »
Hi igel513, Thanks for your reply. The fuel filter changed about 10,000 miles ago. So I think it should be fine...
shaker_chi
I would still borrow the fuel pressure guage to make sure before you start buying a new fuel pump and tearing apart your trunk.
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
Sure sounds like the pump esp. if you're not hearing it hum. I'd replace just the insert.
1996 850 Turbo Wagon
wa98146
Post by wa98146 »
Yep. It was the pump and replaced the just the insert. Thanks all for your help!
Ben850
Been thanked: 7 times
Post by Ben850 »
'93s are fun aren't they? It's a challenge to own what was essentially an experimental year. Mine has since evolved.
When I first got it a year ago.
original '93.jpg (66.8 KiB) Viewed 2565 times
Recent facelift.
Recent facelift.
A Grille day.jpg (55.83 KiB) Viewed 2565 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
