Hi all,
I have a 2002 S40. Today I was idling and noticed that the air conditioner suddenly sounded louder. I turned it off with the fan still on auto and the temp set at 72 and it seemed to to get quieter so am thinking it's the compressor. The air system was completely repaired in 2006. I am hoping there's a maintenance fix for this. Does anyone know about the air system and what the new sound might indicate?
thanks much, Kathleen
S40 air conditioning sounds suddenly louder
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
If the system decides it needs recirculated air from inside instead of fresh air from outside to reach cooling goals it will automatically select recirc.
Turn it on and set fan manually to almost highest speed and then depress the recirc button (pictogram with an arrow circling inside the car) and see if that noise increase is what you heard.
Fish stick88
- Year and Model: 1994 - 850 Sedan
Should that not work, a video of the sounds would help, Videos are awesome on this site. Hope that works for you though!
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
jimmy57
Another thing I didn't mention: S40/V40 models used a function where recirc is automatically selected when you stop when temps are above mid 80's. A/C warms up when engine speed goes down to idle, switching to recirc offsets this so they put the auto recirc feature in.
The car has a cabin filter and if it is getting stopped up the fan will be louder.
- 2010 Views
Last post by Prairiemaster1
- 7685 Views
Last post by buffmont
- 13 Replies
- 2469 Views
- 560 Views
- 6312 Views
Last post by DreaMan64
