windshield pillars peeling
has anyone else had the problem of the fabric peeling off the A pillars on either side of the windshield? I have an 09 S60 that the pillars were replaced at 25000 miles for this problem and now the fabric is peeling off again at 37000. All my windows are tinted to the max legal limit for Texas and I use a sun shield that doesn't even come in contact with the pillars. I don't know what else to do to keep the sun and heat off the pillars or if that is even the problem. I have a 97 850 wagon that the A pillars are a solid plastic like the rest of the interior trim and have never had that problem. I would really like to find a solution before the car is out of warranty, 50K or 5 years.
Fish stick88
- Year and Model: 1994 - 850 Sedan
Not familiar with the newer S60's but if its adhesive, maybe try something a little stronger. Might not be OEM, but It should hold better. Again, its not my box of rocks. Just a thought.
AJ
AJ
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
My 01 S60 has the plastic trim pieces on the A-pillars
My 07 S60 has the fabric covered trim pieces on the A-pillars
The latter are still secure and smooth and show no signs of separation. So, I think you may have had some bad luck with a batch of adhesive or something. It doesn't seem like an inherent design flaw.
One thing to be aware of - if the underlying substrate is contaminated (oil or greasy film from the factory), this will definitely make the adhesive come loose sooner. Since it happened twice to the same pillar from two different sources, I would suspect that's the problem.
Take it back to the dealer.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
caliwagon
- Year and Model: 2007 XC90 V8
My coworker has an 07 S60 and I've noticed it having this problem. Probably because it gets parked in the hot California sun.
2007 XC90 V8
1998 S70 T5M
1986 Mercedes Benz 190E 2.3-16
Favorite past rides: 1998 V70 T5M, 1967 1800S, 2002 Subaru WRX
1998 S70 T5M
fazool
BAH!
I looked at my 2007 pillars and yes they ARE starting to peel at eh edges. Barely noticable but starting.
caliwagon
Maybe install some of the earlier hard plastic A pillar covers instead--the non cloth-covered ones from 01-04 cars. Not as luxurious, but you avoid the peeling issue. I believe the color is the same.
2007 XC90 V8
1998 S70 T5M
1998 S70 T5M
fazool
Isnt there an airbag release near there that might be impeded slightly?
I spoke to the senior parts guy at my dealer, as sharp as anyone in the service department. He said that Volvo has acknowledged the problem and that they have over 500 back orders for an improved design pillar.
JRL
- Year and Model: Several
- Been thanked: 16 times
I've replaced them with the earlier hard plastic/vinvl ones and they match perfectly!
No airbag issue
Nothing is in there except a ticket clip holder on the left side
No airbag issue
- 11 Replies
- 1519 Views
Last post by Polestar
- 2327 Views
Last post by 98v70dad
- 642 Views
- 4840 Views
Last post by theWIFES_S70
- 1984 Views
Last post by pkc303
