How to remove seats V70T5
Bern Davies
- Year and Model: 1998 V70T5
What is the best way to remove the front seats in my 98 V70T5 ?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Unplug and unbolt. It has 4 bolts. Not sure if the side impact bags on those are hooked into the SIRS system, if so, you would want to disconnect the battery.
There are 4 bolts under the seat (14mm) and 1 bolt that holds the seatbelt to the side of the seat (12mm). Then you have 2 electrical plugs on the drivers side, maybe the same on the passenger side.
- 1342 Views
Last post by 1337
- 2613 Views
Last post by Fyndler
- 7150 Views
Last post by SuperHerman
- 836 Views
Last post by regent
- 561 Views
Last post by draser
