About a month ago the CEL started coming on on my 2001 V70 T5, but turns off after about a minute, this happens regardless of cold start or warm. Since it goes off, the guy at autozone couldn't read any codes. The car is up for state inspection so it's important to get this fixed in the next 3 or so weeks.
Do any of you care to take a guess as to what's the problem?
I might not mind investing in a reader myself, but how could I tell if it would read codes that aren't saved or set or whatever the proper term is?
Check Engine Light turns off after about a minute
Did the guy at Autozone actually try to read the code? Sometimes there can be a code even if the light goes off.
A code reader is worth every penny.
2001 V70 2.4T 150,000 miles
1985 BMW 535i 285,000 miles
1999 Lexus RX300 190,000 miles
igel513
- Year and Model: 2003 S60 T5
- Has thanked: 1 time
The light illuminating on yhour dashboard is not a CEL or DTC. It is the service reminder (time to change oil). It will light up upon starting your car and turns off in about a minute. That's the reason why the AZ guy could not find any codes. Do a search on this site on how to reset your service reminder.
Is the DTC the message that appears in yellow-orange on the lower right side of the dash?, I've seen the service reminder and reset it in the past, so I'm more inclined to it being a CEL.
The autozone guy did try to read the codes, there were none "set", but I'm not sure if there maybe? are other registers that his reader may not have access to, or that the guy doesn't know how to look for them.
I'll do the service reminder reset later today and report back. Thanks.
2001 V70 T5 - 150k miles and going strong
JRL
- Year and Model: Several
- Been thanked: 16 times
It says CHECK ENGINE or SERVICE ENGINE, one or the other.
RaymanSean
- Year and Model: V70 XC, 2001
usually if the triangle illuminates (orange-yellow (warnings, lights out etc), or red(stop car, fix problem, doors open, fluids low etc)) there is a message to be read on the text display.
As igel513 said, this was in fact the service light, I wasn't paying attention upon starting the car that the check engine light is different. The light I was getting says "service" and the check engine light says (duh) check engine. I've gone through the key+trip meter dance to reset this indicator and now my car is happy and ready for state inspection. (The oil isn't due for a change for 700 more miles according to the schedule/log I have for the car)
Thanks guys!
Thanks guys!
- 1010 Views
Last post by Cookie-the-Swede
- 2342 Views
Last post by ggleavitt
- 2829 Views
Last post by NYVolvo1994
- 1628 Views
Last post by MadeInJapan
- 12 Replies
- 2087 Views
Last post by veektor
