Hi,
The dealer's mechanic told me the CEL code pointed to the air pump being bad. How can I check if the pump works or not? I have it out of the car, should I be able to feel the pump work if I connect the wiring harness and start the engine? Is this a 12vdc device?
Thanks
Bern
98V70 T5 Air Pump
Bern Davies
- Year and Model: 1998 V70T5
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
A common failure of this air pump is that they fill up with water after a period of time and then stop working. It will leak a bunch of water when removed. You can hook it up to 12 volts to test it. Mind the polarity. This is how I tested my junk yard replacement. I replaced mine with a SAAB pump. I had to swap a few parts between them but it works fine. I think this subject has been discussed quite a bit in this forum.
Les is more.
Bern Davies
Thank you, I'll dig a little deeper in the forum. The old one had no water in it, but the shaft was really stiff to turn, probably bad bearings. In the mean time, I replaced mine with a used Volvo one of same model. We'll see how that works.
Fish stick88
- Year and Model: 1994 - 850 Sedan
Volvo is terrible with these air pumps, I know there are a few links in the Repair database, showing you how to do some exchanges with other types of pumps, VW i think specifically.
Good luck!
Remember! its only time until your next one goes out!
Good luck!
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
- 1761 Views
Last post by erikv11
- 1288 Views
Last post by 850 LPT
- 658 Views
Last post by 98v70dad
- 915 Views
Last post by sleddriver
- 872 Views
