Aftermarket head unit will not turn off
volvo850black
- Year and Model: volvo 850 1994
I installed an after market headunit in my 94 850 NA. I bought the wiring harness. I hooked everything up and it works great except it doesn't turn off when the car is turned off. Afraid my son who drives the car much of the time will leave it on and kill the battery. There were two extra wires on the harness that did not have a companion on the unit. One was orange the other was blue. Does anyone know what can be done to remedy this issue?
MattC 94 854 NA and 96 855 turbo
schmidm90
- Year and Model: 2000 V70 XC AWD
When I installed mine, the blue wire is for a power antenna and the orange one is a dimmer(not 100% sure). To me it sounds like one of the wires got crossed. There should be a red power wire and a yellow one that only gets power when the key is on. If the radio does not get the signal from the yellow wire that the car is off, it wont shut off.
http://imageshack.us/f/233/v70radiosk3.jpg/ is a diagram for the wiring for a V70 which might help to eliminate the problem.
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
2000 V70XC - 199k
volvo850black
I hooked up both of the yellow and red and even switched therm to be sure still won't turn off. Guess he better remember to turn it off or get stranded.
db130
- Year and Model: 2002 V70 T5
sounds like the switched 12V wire and the constant 12V wire may have been switched during the install?
If you have a factory deck installed, does it switch off when the engine is shut off?
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
That's what I was thinking, as far as the constant and switched getting reversed.
When I hooked up the Metra harness to my last Pioneer unit, each harness was an exact match color for color between the pioneer harness and the Metra.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
volvo850black
This is a metra harness and I have tried switching the power wires no change and yes the factory unit did turn off with the ignition. I have installed wired and audio put systems in dozens of cars without this much trouble.
Matty Moo
That doesn't make sense. What brand is the head unit?
2000 s70 GLT
2014 Ram
- 620 Views
Last post by leapdragon
- 1756 Views
- 895 Views
- 2164 Views
Last post by BEJinFbk
- 1559 Views
Last post by Eddystone
