01 S60 with gas smell
dirtysouth_boy
- Year and Model: 2001 S60 2.4T
I've got an 01 S60 2.4T that seems to have developed a gas smell that is pretty strong on the passenger side of the car. I've already taken the backseat out of the car to check around the fuel pump and it's not leaking. The lines don't seem to be leaking either. There doesn't seem to be a gas leak from what I can see. Are there any other parts I should maybe look at like the fuel filter or another possible spot where gas could be leaking.
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
Yes, my 2001S60 2.4T developed a leak under the passenger seat. It was the fuel filter, which is right there on the underside. It rusted out and the leak got progressively worse. Its super easy to change and a new one from the dealer is only like $30.
In my case, the leak progressed enough where it was dripping on the driveway.
Gas evaporates quickly so you may not notice fluid pooling underneath until it is really bad (like mine).
I would confidently guess its your fuel filter.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
caliwagon
- Year and Model: 2007 XC90 V8
I thought at least some '01 S60 had a fuel pump recall (or just a service bulletin?). Seems like some plastic part in the fuel pump commonly cracks. When my '01 S60 T5 developed the same fuel smell (in the same place), the dealer replaced the fuel pump for free under this program.
2007 XC90 V8
1998 S70 T5M
1986 Mercedes Benz 190E 2.3-16
Favorite past rides: 1998 V70 T5M, 1967 1800S, 2002 Subaru WRX
1998 S70 T5M
dirtysouth_boy
I'll have to tear down into the fuel pump I guess. Is there a way to maybe just get a hold of the plastic piece? I highly doubt they will replace it for free since the cars 13 years old now.
igel513
- Year and Model: 2003 S60 T5
- Has thanked: 1 time
Remove the backe seats and you'll see access window bolted on the floor. Remove bolts and cover to see if fuel pump is leaking. If it is then call your dealer to check if it's still covered by the recall.
caliwagon
Did you ever get a letter about it? I think I got the letter within the last 2-3 years, so I assume it would still be covered.
Thread about it here: https://www.matthewsvolvosite.com/forums ... 17&start=0
2007 XC90 V8
1998 S70 T5M
1998 S70 T5M
dirtysouth_boy
I bought the car used back in 2010 so I never got a letter. Also it is leaking gas around the pump so looks like I'm gona have to replace it. Are there any pumps out there that are built better then the OEM's?
dirtysouth_boy
Are there any epoxies or other materials that could plug the hole? It would be a lot cheaper this way. I've look at it and the hole is pretty small but it's inside the circular piece that protrudes through the top of the pump.
dirtysouth_boy
Really like the help I've gotten here. Has anyone had any experience with the part numbers on these pump. The model number on my pump is 8649681.
Which I've looked everywhere and the part is no where to be found. The only ones I can find are the ones that look like this that are the only ones that come close.
Are the two possible interchangeable?
- 2452 Views
Last post by mountain73
- 879 Views
Last post by 93Regina
- 1636 Views
Last post by ir637113
- 3075 Views
Last post by Lvevans55
- 11 Replies
- 4673 Views
Last post by erikv11
