Last week we got a monster storm and my car sat under a heavy stream of water coming off a gutter for about an hour.
A couple days later, on the first start up the car idled really rough, not a surging or dipping idle, more of a very rough vibration.
It smoothed out after 15-20 seconds and drove fine for a few days.
This morning, after another rain, I had the same symptoms on intial start up, but not quite as rough. Again, it went away after time and drove fine. No CEL.
Plugs are new (6 months ago) Volvo. But I don't know when the last time the wires or caps were changed.
Could moisture be affecting the wires and then drying out after I start driving?
Rough Idle After Heavy Rain
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yes, definitely - especially if there's not a good rubber seal behind your hood near the windshield. I've done the same to mine when I've sprayed the oil off the engine at a car wash.Could moisture be affecting the wires and then drying out after I start driving?
'98 S70 T5
2016 Chevy Cruze Premier
You know, it's funny that you mention that, because I opened the hood the other day and the rubber weatherstripping that runs beneath the windsheild at the rear of the engine compartment had popped up. I will check the wires and caps and probably just change them to be on the safe side. What do you think?
'98 V70 GLT
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
If you don't know the age of the wires, I think changing them, albeit expensive, would be your best bet. The car will run much smoother. I had a similar problem, and that fixed it.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
jblackburn
+1. And use Bougicord wires, not Bosch, not other aftermarket brands. These cars are incredibly picky about things like that.
'98 S70 T5
KlubMarcus
- Year and Model: V70 XC, 1998
Still running Bougicord brand wires myself. They are the OEM supplier for Volvo. See, the French can do something right!jblackburn wrote:+1. And use Bougicord wires, not Bosch, not other aftermarket brands. These cars are incredibly picky about things like that.
- pkc303
That's terrific. Good luck. Alwick, please post what your findings are to complete this thread.
- 2243 Views
Last post by An R rated life
- 2096 Views
Last post by jonesg
- 2056 Views
Last post by Clemens
- 1497 Views
Last post by precopster
- 3667 Views
Last post by jalwlb
