Hi, my outside temperature display reads correct temp when I start ignition. However when I begin to drive the display counts backward to 66 degrees. I replaced the sensor in the mirror about six months ago. Could the problem be anything else before I call a garage?
Susan
Outside Temperature Display on dashboard.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
That problem is well known to Volvo shops. The connector from body to door has corrosion/connection issues. You likely will see that temp display go back to an accurate temp if you open the door.
- 814 Views
Last post by oragex
- 1502 Views
Last post by Webpirate
- 1779 Views
Last post by Oka
- 4857 Views
Last post by EChem
- 484 Views
Last post by rubbersidedown
