The car has 184997 miles on it and the replacement engine has 126,325 miles on it.
What I got was a long block and then some. It came with all of the accessories - AC compressor, alternator, PS pump, intake manifold, electronic throttle module, exhaust manifold, coil packs, and turbo. The car was severely wrecked - all four corners and the engine got crammed back into the firewall but after it came out there was no real damage to the engine but the power steering pump and the mounting bracket for the accessories didn't fare well at all. The timing belt cover on the replacement engine is a goner so I will need to use the timing belt cover that came with the car rather than the engine. The replacement engine serial number is documented here for posterity.
I picked up the engine on Tuesday afternoon (7/31/2012) and I borrowed an engine hoist from my Nephew later that evening and got the engine out of the Suburban.
Knowing that this was pretty much a done deal I ordered in a bunch of parts on Monday (7/30/2012) and the OEM stuff showed up on my doorstep the next morning. I ordered the PCV parts, the timing belt parts, and the RMS all OEM since I have seen the nightmare that some have had with URO oil lines. The OEM timing belt components were also cheaper than the aftermarket guys. The Rear Main Seal is something I don't want to do again after the engine is installed so I ordered it in OEM as well. I forgot stuff like intake manifold and exhaust manifold gaskets and various other little things like new copper washers for the banjo bolts on the turbo and a seal for the coolant pipe that runs down the exhaust side of the engine. My parts from the aftermarket supplier showed up today as did my second mail order from the dealership.
Many of the lines on the replacement engine were deformed or otherwise damaged from the wreck so they will need to transfer over from the old engine after it comes out so I ordered in the appropriate seals and gaskets to deal with those parts.
On Wednesday (8/1/2012) I got the engine on the engine stand and stripped off all of the old accessories and what was left of the wiring harness . The 1000 lb Harbor Freight engine stand really sucks and it cocked the engine at about a 45 degree angle once the engine was lowered off of the engine hoist. I am quite certain that the engine doesn't weigh even close to 1000 lbs but I got it back to more or less level with the engine hoist and stuck a jack stand in under it. I replaced the PCV components and called it a night. It was by far the easiest PCV servicing job I have ever done.
Thursday and Friday got eaten up with work so I will dive back in on this on Saturday (8/4/2012) morning after I finish my tasks at my daughter's new apartment. By the end of the weekend I hope to have the cam seals and the timing belt with all of its parts, including the water pump replaced. I also hope that I can flip the engine over on the flimsy stand and replace the sump O-Rings and get the pan re-sealed. I also have new turbo coolant hoses and stuff to re-seal the turbo banjo bolts but they will need to be replaced after I pull the old engine and swap over the pipes.
If anyone needs pictures of anything related to the engine please let me know ASAP and I can get good closeup pictures while the engine(s) is/are out of the car.
