98 V70r, Bad Fuel level sensor?
ct98saffv70r
- Year and Model: 98 v70r
So this just happened. started the car, fuel level read as empty.. went and put a couple gallons in it to run an errand. No change. Then after i went to fill it, it only took about 10 gallons, it seems. Started the car and the gauge did jump up for the gauge test.. oddly right to 10 gallons and fell back to empty. "Miles to empty" is naturally not working.
- Year and Model: Many Volvos
- Been thanked: 76 times
A bad sender could indeed cause your problem. I have not had one out on a Volvo but the one I yanked out of a Porsche 944 was just a float that tracked along a nichrome wire. After I cleaned the crud off of the wire and the contacts to the wire it worked fine.
ct98saffv70r
Is the level sensor part 9470840? Seriously almost $400? i could imagine for a pump.. but just the level sensor?
- 276 Views
- 919 Views
Last post by sleddriver
- 14 Replies
- 12395 Views
Last post by pgill
- 9265 Views
Last post by titodj
- 529 Views
Last post by gnalan
