Unless she's towing a trailer, she doesn't need the OD disengaged. The OD switching is noticeable regardless of which gear the trans is in. The default is disengaged OD.
To eliminate the kick-down, count the shifts the trans goes through as you get up to speed. The kick-down could be out of adjustment or hanging up in the cable sheath. It should have about 5mm slack.
Buy the OD bypass plate if that is the problem
Ed
DL240 overdrive and kickdown cable on automatic
ed7
- Year and Model: V70XC 2005, 2001
- Has thanked: 2 times
A broken wire is common under the car. The solenoid doesn't make a lot on noise, it's barely noticable.
If you're getting voltage on the solenoid wire under the car, the solenoid/valve is shot.
Ed
Ed
- 1738 Views
Last post by mhgreen
- 692 Views
Last post by hideogumperjr
- 1344 Views
- 11 Replies
- 4489 Views
Last post by gusinfantino
- 994 Views
