Key fob module: have it flashed?
i bought a complete xc70 parts car that came with a key fob, my question is if i switch the module from the xc to my v70, with the fob unlock my doors, or will i still have to have it flashed?
Reason: Edited title for clarity. Please use descriptive titles.
- Has thanked: 312 times
- Been thanked: 818 times
What year is the parts car?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Sorry. A module swap is a no go.
The 98 vs '99-'00 are different systems.
You can use the '99 fob, but you'll
need a dealer to add it to the '98.
thanks, i noticed alot of little differences between the two. So it should just be a matter of flashing the ecu to recognize the key fob?BEJinFbk wrote:Sorry. A module swap is a no go.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Actually the VGLA system is the same. The answer is still no, don't change it though.
98 required access codes (PIN's) to be used with the Volvo Scan Tool to program remotes and make settings changes.
99 and later 800 platform models use VIDA to do those things. To make the sales and handling of the access codes be more automatic they treat those access codes as software. So the 99 up require VIDA and a software purchase to program remotes and make settings changes. The 99 module will install and work with that one remote but anything you ever wanted to do in the future would be roadblocked.
So to answer: you need to go to a dealer and they can add your remote. The access code for programming remotes is on their VIN lookup system in the same place as key codes and is not charged. The ones for settings changes is handled through parts and Volvo charge the dealer for those.
