Valve cover torque specs 2002 V70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Volvoinhawaii
Year and Model: 2002 V70 turbo
Post by Volvoinhawaii »
I need some information on the torque specs for valve cover on my V70 turbo 2002. I also need to know the tightening sequence. mahalo
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
They are 7Nm so not too tight. The force of 42 bolts all acting on the cover as well as the gluing effect of the sealant bond the cover very well.
Try to bolt them all down evenly as they take if you're not using the cam cover clamps. I use a Ryobi 18V battery drill with lowest torque setting on speed 1 and go around multiple times until it's down. Each tiny amount of turn lowers the cam cover down and threads don't get stripped.
Use fresh oil on all your well cleaned bolt threads and be sure the threads in cylinder head are clean and tested. I usually do a cover down without cams on first to check for burrs/problems in seating.
Sent from my GT-I9100T using Tapatalk 2
Volvoinhawaii
Thanks...do you know where to get the valve cover seal and things I will need?
precopster
Volvo anaerobic sealer part number 1161059 dealer cost around $40. This stuff stays wet when in contact with the air but dries when sandwiched by aluminium; weird if you haven't used it before!!
Comes in a tube will also need spark plug o ring seals X 5 part number 1397525 and that's it.
Sponsor banners above is best place check prices.
Has thanked: 1511 times
Been thanked: 3827 times
Old thread.
Permatex 518 costs about $10 and I did six head covers with one tube.
Ok, one head cover six times
