Rough idle after cold start
Msuperbauer
- Year and Model: 850 GLT, 1995
Only for about 30 seconds, then clears itself out and car runs great. When I start it in the morning it sputters and idles real rough, then just stops and runs perfectly normal?!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Do you have a CEL? Any codes? The most common problems are a dirty idle control valve, sticky throttle body or a bad temp sensor.
Msuperbauer
No CEL's, although I DID just run seafoam through the gas tank. It runs worlds better (after the rough initial idle works its way out) Does that help narrow it down?
Msuperbauer
Ok, removed and cleaned out the idle/air control valve and it seems better, BUT issue still seems to be happening.. BOOOO
Msuperbauer
update: Looks like new spark plugs solved the problem. Swapped them out today and baddabing! Problem solved. I was thinking today (this is what happened to my lawn mower) hard to start after having old gas, it was running rich and it fouled the plug. So I thought, maybe the seafoam caused my Volvo to run too rich and foul a plug or 2.. Correct I was!
- 1975 Views
Last post by towanas
- 940 Views
- 962 Views
Last post by sweedespeed1
- 3833 Views
Last post by WhatAmIDoing
- 17 Replies
- 1581 Views
Last post by vtl
