I found a post that led me to this Amazon page:
https://www.amazon.com/s/ref=nb_sb_noss? ... nsor+15717
Poster said he was happy with the 15717. I guess if it gives lamda that's all that's needed, right?
What would be the best way to splice the wires? And, are they color coded?
Can I use generic CO2 sensor, like these?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Volvos hate those things. Go with the direct fit sensors.
'98 S70 T5
2016 Chevy Cruze Premier
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
I used a Bosch 13877 sensor in the front position of the 96 850. Still working fine 10 months later.
https://www.amazon.com/Bosch-13877-Oxyge ... osch+13877
I use end to end crimp connectors. Its more reliable than soldering.
Ambitious but rubbish
- Has thanked: 311 times
- Been thanked: 817 times
Apparently with those sensors that do not have the direct fit plug connectors, it's all in the crimp.
Because the function of the sensor is to transmit a stable electrical signal, the connections have to be very good, and must hold up well over time after repeated sessions of extreme heat and cooling. A lot of people have trouble when they do the DIY crimping, but if you have more experience than "hey-just-crush-the-wires-in-there-really-good" then it may work for you.
- Been thanked: 504 times
For the records, there is a difference between CO2 and O2 sensors.
OK, I will keep my mouth shut before JimBee kills me LOL.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Thanks to tjts1 for the pointer on
Oh, yeah. CO2, what was I thinking? Just tired, I guess when I posted that one. At least I didn't call it genetic
I can handle corrections : )
But Erik or others, if you read this, what's the trick to making a good crimp?
madspeed50
- Year and Model: 1998 S70 T5m
I think this is the direct fit one, no crimping crap needed...
https://www.amazon.com/Bosch-17137-Oxyge ... nsor+17137
Yep, sent from my rooted, rommed Galaxy Nexus....
madspeed50
I didnt see that those were that cheap. I would be sure to solder the connections though, less resistance and less chance of seeing issues with the crimps
tjts1 wrote:$55 extra just to avoid crimping 4 wires?
There have also been discussions on this on the board about soldering, again because of the conditions it is exposed to, I think soldering is even more likely to be inadequate. Just relaying what I've read, don't mean to be a killjoy ...
jimbee, I know there have been threads here about crimp techniques that work, that's about all I can come up with right now. Search, you may be able to find it.
Negative, the direct fit sensor for the front is Bosch 15097: https://www.amazon.com/Bosch-15097-Oxyge ... B000BZI3G2madspeed50 wrote:I think this is the direct fit one, no crimping crap needed...
- 748 Views
Last post by volvolugnut
- 18 Replies
- 2514 Views
Last post by jimmy57
- 645 Views
Last post by misha
- 1756 Views
Last post by jjlch
- 1104 Views
