Engine will not turn over.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
almet727
Year and Model: 1996 960
Post by almet727 »
Starter will not engage engine when key is turned. Engine will start when starter is jumped from beneath. Any suggestions?
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Ignition switch?
PNP switch located on transmission?
1988 Volvo 760 Turbo Wagon
almet727
Post by almet727 »
Thanks for the reply. I know very little regarding engines and even less regarding foreign cars. What is a PNP swithch and where is the ignition switch? My son will be doing the work.
lummert
Post by lummert »
The PNP is the start inhibitor that prevents the engine from being started when the shifter is any position other than park or neutral. The ignition switch is on the steering column directly opposite of the ignition lock cylinder on a 960. The ignition switch can be found after removing the lower cover on the steering column.
Fred760DC
Year and Model: 1990 760 SW
Post by Fred760DC »
Volvos will not start unless there is oil pressure. Check the oil
