So 3 years after doing a Auto to Manual (standard) tranny i am looking at getting the cruise control working again, it worked well before but after removing wire 3T from the relay it still doesnt work...?? anyone know its a 1998 V70 T5
http://www.volvoforums.org.uk/showthread.php?t=71697
Cruise Control not working
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- darylrobert
does anyone know what im missing?...
madspeed50
- Year and Model: 1998 S70 T5m
vacuum lines all check out?
Sent from my rooted, rommed Galaxy Nexus....
- Has thanked: 311 times
- Been thanked: 817 times
Yeah you must start by testing the vacuum lines, most common problem is the rubber elbow under the battery tray rots out. Or it could be the brake switch, etc.
There is a great troubleshooting guide in the Volvo manual, to systematically test each component. It is a 95 manual so you can't run the OBD1 tests, but otherwise will be totally accurate for your 98 (e.g. jumper tests for the relay and the pump), download it from here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
Once you unzip it see the file called cruise control system.pdf, it instructs the tests.
- darylrobert
All fixed, thanks guys.
the brake switch wasnt working, took it apart and cleaned the contacts.
- 5263 Views
Last post by THeOldMan
- 693 Views
Last post by howardc64
- 32 Replies
- 9777 Views
Last post by zhenya
- 714 Views
Last post by Denwiley
- 1264 Views
Last post by RickHaleParker
