2006 XC-70 with Bridgestone Ensignium SE 200 size 215 65 R16 tires need replacement & I’m not really happy with handling.
Considering going wider to 225 65 R16 Goodyear Eagle LS2 or Michelin MXV4.
Will 225 fit without hitting?
(I know this tire will be a little taller and actual speed may be higher than speedo, but I’m hoping the increased load rating will reduce the sloppy handling and overloaded catch-up feeling in corners.)
I don’t want the “stickiest” tire available, although that would be nice, because I have to compromise with an “all season” tire (not enough $$$). Any thoughts?
Thanks!
2006 XC-70 Tires
FattyArbuckle
- Year and Model: XC-70, 2006
Running: '79 245, '89 245, 2006 XC-70, '93 PGT
Not Running: '69 Spitfire, '68 Lancia Fulvia Coupe, '80's Alfa Sedans
Wish I still had: '69 124 AC, '72 2L Pinto Wagon, '60 302 Falcon
igel513
- Year and Model: 2003 S60 T5
- Has thanked: 1 time
If you want to go w/ 225, you have to go lower to 60 to compensate for the extra width. I learned that from a tire guy at PepBoys. So go w/ 225x60x16. Your speedo will register about 5 more miles than the actual speed. So if speedo is showing 65mph, you're actually only going @60. Thats a neat trick to do on youngsters' cars to slow them down a bit.
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I currently run 225/60/17 and they fit no problem. You will be able to fit 225/66/16 on there with no issues other than speedo being slightly off. In fact the tires you are talking about are 0.4% SMALLER than the one's I am currently using.
Jesse
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- 3271 Views
Last post by SuperHerman
- 2144 Views
Last post by benrk
- 1651 Views
Last post by precopster
- 1118 Views
Last post by rspi
- 930 Views
Last post by sinclair
