Help identifying a mystery line/hose
wingwang
Year and Model: V70 GLT 98
Post by wingwang »
Hi, I'm hoping someone can help me figure out where this line is supposed to attach on my 98 V70 GLT. I was replacing a leaking heater hose today and when I pulled out the air filter housing, I found this line just hanging out under the lower portion of the filter housing. It is a black rubber vacuum elbow attached to a hard white plastic line that runs to another black rubber line that is attached to a small metal pipe that runs along the backside of the engine along a coolant inlet from the lower radiator hose. The only text on the white line is "VOLVO 967563". I have included a picture below. It is the line with the red squiggle running through it and the arrows pointing at it.
The car runs fine, no check engine light, no issues. When starting the vehicle, the hose doesn't seem to have any vacuum when I put my finger over it.
I appreciate any help. Thanks in advance!!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Seems to short to go to the cruise control. Maybe it connects to the intake tube just behind the MAF. My car is turbo so I'm really not sure.
