My 93 244 has a stumble on acelleration off idle only when the car is driven for at least 30 minutes on a warm day (over 80°F). If I let the car cool down for a few minutes with the hood open, the engine runs normally. There is suffiecient coolant and the temp gauge is in the middle.
The check engine light is not on and I will check the DTC tommorow night when.
Can this be the ETC sensor starting to not work?
Aaron
240 Acceleration Stumble
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Code 214 is the engine speed (RPM) sensor giving an intermittent signal.
The sensor is mounted in the top of the bell housing, down behind the engine. It is not unusual for the wiring to chafe and break the insulation causing problems.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 1538 Views
- 1113 Views
Last post by maddog2020
