Hello,
I need some help please. There is a persistant irritating rattle in my V70 and it comes from the back left hand area and is particularly obvious when I am travelling on country roads which are less smooth, on the motorway, it is not such a problem.
Having checked all of the plastic fittings around the tailgate area, to find that they are all very firm, I have checked the tailgate, it is not loose, open or closed, I have checked under the floor in the storage compartments and where the spare is located, nothing it seems would seem to be contributing to this irritating rattle.
The one thing that I have not checked is the rear wiper motor and assembly, which sits in the void behind the rear carpet in the tailgate.
This is not the first time I have come across this problem, I have had two 850 wagons in the past and both exhibited the same problem. Then I was prepared to accept it, now I am not
Any help or sensible suggestion would be much appreciated.
Thanks,
James.
Irritating rattle.
JamesUKV70
- Year and Model: 1998 V70 CD T5
1972 145 GL Wagon
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
1999 V70 SE 170bhp Wagon
1998 V70 CD T5 240bhp Wagon - (Best car I have ever owned)
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Have you checked the rear shock mounts? Remove the carpeting in the tailgate area, they'll jump right out at you, and they are a common failure item.
5 others that came and went
JamesUKV70
Cheers, I will look right away as I am already searching around the back end of the car!!
Thanks for the suggestion,
James.
James.
1972 145 GL Wagon
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I have this issue with my V70. Now in my case it was the back seat, flipped it down and noise is gone. No plans to fix since all I wanted to know was that the noise wasn't from something falling apart. My hearing is pretty poor and hard to get any directional sense but I knew it was coming from the back.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
JamesUKV70
Great helps guys; I will check out all of your suggestions and hope that I can rectify the problem.
Cheers, James.
Cheers, James.
1972 145 GL Wagon
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
1975 245 GL Wagon
1979 245 GLE Wagon
1982 345 GL Saloon
1986 740 GLT Wagon
1987 740 TD Wagon
1990 740 TD Wagon
1994 850 T5 Wagon
1995 850 GLT Wagon
DrewsT5
- Year and Model: '95 850 T5 Wagon
Sometimes it a simple thing. Perhaps it's just the rear seat latch that is rattling, like the others have mentioned. One cheap fix is to use electrical tape and wrap it around the latch a few times. That way you eliminate the metal-on-metal rattling.
