91 240 transmission
patchwork
91 240 transmission
I have a 1991 240 with automatic transmission that will not shift into high gear. I have had the transmission serviced and the mechanic thought the problem might be electrical. The problem started by the transmission down shifting into passing gear for no reason, and then not shifting back up. Now the transmission will not shift into high at all. Any ideas?
dpauto.com
- Year and Model:
You might have a bad overdrive relay or bad overdrive solenoid. Or possible bad transmission.
Is the arrow light on at the moment?
Dave
Dave
ASE - VOLVO Master Technician
- 1109 Views
Last post by ducttapeandzipties
- 891 Views
Last post by maverill
