Loss of oil and power
855 moneypit
Year and Model: 850 1995
Post by 855 moneypit »
First off, the motor has 310k miles and is a touch tired but still has plenty of pep. However I am now experiencing a substantial loss/lag in power delivery when I get into boost. The motor is revving and willing but there's no kick at times. Other times it will take its time then start to pull. I get around town and the freeway just fine. I have been very careful about getting into boost.
I checked the hoses and the top inter-cooler hose is quite soft. Due for replacement obviously. I then checked around the turbo to find this
Looks like a nice sized rip on the coupler. Major cause of power loss?
I have also been losing more oil than usual. In my search for a source I notice oil on the passenger side cv boot by the timing cover. I pulled the cover and noticed oil/grime on the lower corner.
I looked around some but didn't see any source of oil coming from the front cam seals. Anywhere else I should be looking for an external leak in that area?
byeboy
Year and Model: 850R, 1997
Post by byeboy »
The only way to pin down the source of the leak is to clean off what's there (Gunk Foamy works pretty well, after dry, some brake cleaner will get suspect areas like new, so oil can be spotted...you can buy Leak Detector at Parts Stores, but you may need a UV light to use it...so read the label...visual should be good enough...just drive it a few days after you clean it. I'd leave the belt cover off to simplify spotting the source, but only for ths short timer, and no off-roading, monsoons, etc...
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
when you say a loss in boost, do you know how much boost its making ? If its a auto trans it could be slipping causing the feeling of loss of power.
1996 Platinum Edition
855 moneypit
[quote="phils94850"]when you say a loss in boost, do you know how much boost its making ? If its a auto trans it could be slipping causing the feeling of loss of power.[/quote ]
Transmission isn't slipping. Holds speed fine going up hill. That was my first thought though. The louder, more pronounced WHOOOOSH I noticed when getting into it leads me to that nice little rip in the coupler. Going to get dirty this weekend or next replacing the hoses.
Getting a rotation, alignment and oil change this week. While they have the wheel off I'll take a peek at the lower portion of the timing components. The only place it's grimy is there at the bottom corner.
I also noticed black ( not oil ) residue on the waterpump just inboard of the pulley. Any ideas on that?
phils94850
If your hearing a louder whoosh then yeah prob a torn hose somewhere, id say the oil leak is coming from the front cam seals.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
855 moneypit wrote:Looks like a nice sized rip on the coupler. Major cause of power loss?
Yeah, that'll it. If that's shot, it's a good idea to replace all five of the hoses related to the intercooler.
855 moneypit wrote: I have also been losing more oil than usual... Anywhere else I should be looking for an external leak in that area?
Inspect your oil thermostat and related hoses. It's behind the passenger wheel, just in front of the eninge mount and under the serp belt.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
855 moneypit
Thanks vj, I'll have them check it out when I take it in for oil change and rotation. Be easier with the car in the air.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Is this a crack here in the hose?
If this is a cracked hose from a turbo....that's why you have a loss of power.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
855 moneypit
misha wrote:Is this a crack here in the hose?
That there is a nasty little gash. Aside from teh dealer the only other brand I can find is URO and I'm not too fond of their goodies.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Dealer it is then!
Never, ever, ever buy anything URO. They are evil and must be destroyed :evil:
'98 S70 T5
2016 Chevy Cruze Premier
