Oil leak dripping
panda30
Year and Model: 98 s70 glt
Post by panda30 »
It just happened today, I noticed but I can't tell, it looks like it is leaking behind or at camshaft sensor. It almost drips as though a hose was busted. Can someone tell me if it's a seal? The car runs great, no smoke and has 170k miles. It is a 98 Volvo glt 2.4. I noticed that one of the torx bolts to the cam sensor was really loose. I tightened it but have not ran the car to see if it leaks because as soon as I turn it on it begins to seep oil from behind that area.
Reason: An attempt at clarity.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
could be your rear cam seal..
1996 Platinum Edition
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Agreed, sure sounds like a rear cam seal.
hanseich
Year and Model: 850 turbo, 1996
Post by hanseich »
Instructions on how to change the seal are here:
https://www.matthewsvolvosite.com/forums ... l&start=14
http://volvospeed.com/vs_forum/topic/88 ... 26quot%3B/
The rear cam shaft seal cost me $3.99 (at FCP Groton) for my 850 turbo. Installation is very easy. It is a bit tricky to get the old one out, also be careful when putting the new one in, it has to sit flush and straight or it will leak again.
New to Volvo, already liking it. Hoping to keep it in good shape, not like the previous Benz 190e
Repairs so far: tie rods, outer CV Boot, air control flap, control rod, ABS module, various seals, motor mount
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
For REAR Cam seals, the updated version is here using SKF 11809 ($6/each):
https://www.matthewsvolvosite.com/forums ... hp?t=50752
PS: Avoid Elring cam seals.
hanseich
Post by hanseich »
Good to know not to use the Elring one, I just installed it yesterday. :shock: At least it only takes 30, once it leaks it will be a quick routine. How come FCP does not sell those? Would have preferred it.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I strongly suggest the VOLVO OEM seals. Our S70 had after market seals and they only lasted about 2-1/2 years.
Here are my instructions: http://www.atthetipwebs.com/technologyi ... s70glt.htm
855 moneypit
Year and Model: 850 1995
Post by 855 moneypit »
phils94850 wrote:could be your rear cam seal..
Likely suspect.
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
I'll second the Volvo seals. Don't know why they last longer, but ours need changing after 3 years. They were not Volvo brand.
Will go back with Volvo ones next time.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Post by cn90 »
While I agree that we should use Volvo seal (Rear cam seal is $17/each), however SKF is a major supplier for Volvo.
I installed the SKF seal as mentioned above for $6.50/each.
Bone dry, zero leaks.
I highly recommend using SKF seals, you get OEM stuff at much cheaper prices.
