All items below done over a 12-16 month period as at Sep 2012 not registered Radio Code: 3451
Both sway bar LINK RODS (Meyle) $40 done
Air (Wix) filter $30 done
Coolant temp sensor $25 done
Coolant level sensor $30 done
Heater core $70 done
Heater coupling OEM $45 done
Tie rods $40 done
Control Arms $100 done
Ball joint (Meyle) $65 done
Dust boot for left rack $9 done
Spring seats OEM (front) $40 done
Water Pipe Gasket $2 done
Battery hold down clamp OEM $4 done
Thermostat housing gasket $3 done
Oil sump O ring set $15 done
Spark Plug seals X 5 $4 done
Head bolts X 10 $45 done
Front Cam seals $25 done
Head gasket $35 done
Timing belt & tensioner set OEM $160 done
PCV set OEM $70 done
Accessory Belt 9458376 $32 done
Accessory Belt pulley $25 done
Front Engine Mount Hutchinson $35 done
Front Discs $89 done
Reco cylinder head $650
Front Pads $45 done
Auto Fluid (Castrol Dex III) $55 done
Upper & Lower radiator Hoses $25 done
Heater hoses $50 done
Thermostat & O ring seal $14 done
Cooling Fan relay KAE $35 done
New windscreen $265 done
Silver 1999 V70 NA
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
precopster
- Year and Model: Lots
- Been thanked: 128 times
