pnp switch replacement
I have a 94 960 147k with the following symptoms.It won't come out of park without pushing the shiftlock button,no backup lights,occasionally it goes into winter mode,and the OBD gives me a 313 code.My question is do all the symptoms point to the pnp switch or do you think I have more than one problem....Thanks in advance.....also is there somewhere i can go to download the procedure to replace the pnp on a 94 960.I have found numerous places that show it on 850's but no 960's
- osman
- Year and Model: 2002 c70 hardtop
Try backing off the ignition key it could be the ignition switch wearing out.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Have you checked fuse #27?
Transmission code 3-1-3 indicates a problem with the gear position sensor which is not likely to be connected with the PNP switch.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Went to the dealer and on a 94 960 there is a gear selector position microswitch under the console and the pnp is on the transmission itself(billofdurham educated me on this). Does anyone know which controls the backup lights?
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I have a 94 960 shifter installed in my 88 765. The only thing electrical that I can remember being mounted to the shifter is the switch that switches the relay to the shift inhibitor solenoid. This switch being part of the button that is pushed to release the shifter to changer gear selection.
1988 Volvo 760 Turbo Wagon
That makes sense lummert,that would explain the sticking in park and why i have to use the shiftlock button to get it out of park sometimes,I think I misunderstood what that switch was for.Do you know if there is a backup switch,I can't seem to get the backup lights working
- 11 Replies
- 11373 Views
- 798 Views
Last post by polskamafia mjl
- 1132 Views
Last post by techedbob
- 1325 Views
Last post by 93Regina
- 1162 Views
Last post by jforce
