Shift sequence on geartronic trans fluid change?
rybotix
Year and Model: XC90 2007 AWD 3.2l
Post by rybotix »
I have a 2001 xc70 with 160k I plan on doing a drain and fill on. I am curious as to upon the refill, if I need to cycle the shifter from P to N- to R to D, and then put it in manual and shift up and down from 1st to third?
Also, when draining and replacing, should the fluid be hot coming out...and if so how much to underfill to compensate for thermal expansion?
If anyone has done this, please let me know, these are the only items I am fuzzy on...
Thanks!
Rybot
rybotix
Post by rybotix »
Anyone??? Opinions, facts?
Thanks!
R
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
No need to do any shifter motions.
The dipstick has markings on both sides. go to lower end of the hot (higher) scale.
Full on the hot scale would be for hot fluid from a lengthy drive.
rybotix
Post by rybotix »
Thanks Jimmy57,
Do I change when warmed up though....and check level while running?
Cheers-
R
jimmy57
Post by jimmy57 »
Yes, it is generally best to change any oil when warm so it drains faster and more completely.
All auto transmissions I know of are checked when running on level ground. The torque converter can't be assured to be full without the engine running.
rybotix
Post by rybotix »
Thanks for the help! I did two drain and fills over the weekend and the car shifts like new. Will do one more in 500 miles to get a larger percentage of the old fluid out.
Cheers!
