visual alarm signal
elgataa2006
Year and Model: 2002
Post by elgataa2006 »
hello guys
I have a 2002 Volvo V70 XC Wagon. Yesterday, the visual alarm signal began going on for no reason. It stays on for approximately 5 minutes , its happen once when i come back from work or at work , Any idea as to what might be causing this and/or how to fix it?
mbreed
Year and Model: 2005 XC90 2.5t
Post by mbreed »
While driving?
elgataa2006
no, only happen when is park after driving , in weekend its happen after i come back from work , and didn't happen again until yesterday .any idea?
coflynn
Year and Model: 2002 S60 AWD
Been thanked: 6 times
Post by coflynn »
If you purposely trip alarm, does the siren module work? There is a common problem with the battery in them leaking, yours is well into the age that could be happening at. If the siren doesn't work when the alarm goes off I would almost certainly consider that, although I would consider it fairly likely anyway...
elgataa2006
i don't think the siren work when the alarm goes off , so what i need to do ? i need to change the siren module? any idea how to change it ? and where is located in car?
mbreed
Post by mbreed »
I didn't understand your problem at first. Now I do. The siren is in the RF wheel well. its behind the plastic fender liner bolted to the body. It is mounted with a break away bolt. So to remove, you'll have to get creative.
elgataa2006
i did some reading about siren and how to change it , I'm looking to buy one online , the cheapest one is 206 $$ for new one , I'm going to order one new next week and give the try to change it.
