Hi all
Does anyone know will a 20v throttle body from a 97-00 v70 P1 fit onto a 95 Volvo 850
Andy
Throttle body
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
From a '97 in your part of the world, yes. The cars with electronic throttle bodies (1999-2000 here; possibly 98-2000 for you) will not.
'98 S70 T5
2016 Chevy Cruze Premier
So just to confirm this throttle body will fit on mine?
http://item.mobileweb.ebay.co.uk/viewit ... 8572684022
Cheers
Andy
Cheers
Andy
jblackburn
As long as your car is also a 20V, yes.
'98 S70 T5
jblackburn
For an even better modification, have you considered replacing the throttle body disc with that from a 960?
https://www.matthewsvolvosite.com/forums ... =1&t=19204
'98 S70 T5
Hi Jblackburn thats the mod i'm doing atm. The issue i have found is that in the UK the 10vs have all been fitted with a throttle body from a T5.
So i've got a plate but trying to find a 20v throttle body in the uk is really difficult, however there seems to be loads of the 97-00 P1 V70 throttle bodies with the 65mm plate about.
Cheers for your help. bought the throttle body now, Going to get the head polished as well which should help a little.
Andy
Andy
precopster
- Year and Model: Lots
- Been thanked: 128 times
Forget the '99-2000 20 valve throttle body as it's fully electronic and vastly different. The eBay seller you linked to obviously has no knowledge of this. Not too certain what Volvo did with 10 valvers in the UK between these years, though.
- 1033 Views
Last post by smeha
- 738 Views
Last post by Matty Moo
- 500 Views
Last post by jimmy57
- 791 Views
Last post by MikeHotchkiss
- 1152 Views
Last post by kahl
