Open Crankcase Port? Oil splashing 2002 S60 - 2.5 non-turbo
Hello all, I have a 2002 S60 with the 5cyl. 2.5 non-turbo. Problem is on the exhaust side (back) of the engine there is an open port to the crakcase. Normally this causes no issues however during high RPM's oil will splash out onto the heat shield and smoke. I've attached a couple pictures showing the location of the port, but I don't know what part(s) I'm missing. Any ideas from the experts???
- Example photo showing location of port, marked with a red circle
- Volvo.jpg (64.92 KiB) Viewed 2246 times
- Actual photo of my engine from underneath car
- volvo2.jpg (75.69 KiB) Viewed 2246 times
Reason: Edited title for clarity.
JDS60R
- Been thanked: 3 times
Its the turbo oil return port. Volvo sells a plug. Its just a standard freeze plug. Check local part stores by phone explaining the diameter needed.
Retired
Hi, I could really use some help with this same issue. 2002 V70. I have the plug but can't get it to seat in the hole. Just not enough room up under the exhaust manifold for a large enough hammer, plus the hole is angled upward so getting decent access is really tough. I'm using a 12mm socket inside the plug and a few different smaller hammers. I've also tried every little extension and gimmick I can think of, no results. Just can't get enough force on it to drive it in. Any tips?
swimNdrive
- Year and Model: 2004 xc70
I would try to use a hair dryer to warm up the plug.
DGM
- Year and Model: V70 2.4i 2005
As an interim solution may be this type of rubber expansion plug could help.
http://shop.advanceautoparts.com/webapp ... ubber+plug+#
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
- 19 Replies
- 2842 Views
Last post by prwood
- 1879 Views
Last post by SuperHerman
- 3007 Views
- 280 Views
Last post by cmdz
- 1183 Views
Last post by Capndirk
