Did you know? 🤔
Defeating the torque limit request on the Volvo 850 Turbo
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
henrysin44
Year and Model: 1994 Volvo 855 Turbo
Has thanked: 2 times
Been thanked: 3 times
Sweden
henrysin44
Re: Defeating the torque limit request on the Volvo 850 Turbo
Post by henrysin44 » Wed Feb 15, 2017 4:16 pm
Hey all im new to this thread but ive been following it for abit. Today I finally got around to tearing into a M4.3 ecu I got at a parts yard and well the mod can work sort of. When activated the front wheels spin a lot with WOT from dead stop but nothing like that from light throttle, light throttle has more of a punch though. Actually the first run I did at WOT up a slight incline resulted in my hood flying up so this hack may result in a new hood lol.
Mod done on a 1994 Volvo 855 Turbo, ECU M4.3 -0261 203 072-.
Parts: ECU M4.3, 1K ohm resistor, 20 ohm resistor, NPN transistor capable of accepting 12-13V.
Ok so to do the hack you gotta open up the ecu and find ground, 12v, b2, b3, and b4.
Solder a 1K and 20ohm resistor (in series) from a 12v source on the board to a voltage regulator to make sure the voltage is under 12v but between 8v and 11v.
Then solder the resistor pair to the base of the regulator and the collector of the regulator gets soldered to pins b2, b3, and b4 on the board ( cut the pins out to wiring harness). One extra thing to do that I diddnt was wire a switch before the resistor pair as to be able to controll the mod as ive already spun tire when not intending to.
I will add photos and a schematic soon.
http://shealabs.net
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
henrysin44
Sweden
henrysin44
Post by henrysin44 » Wed Feb 15, 2017 6:44 pm
henrysin44 wrote:Hey all im new to this thread but ive been following it for abit. Today I finally got around to tearing into a M4.3 ecu I got at a parts yard and well the mod can work sort of. When activated the front wheels spin a lot with WOT from dead stop but nothing like that from light throttle, light throttle has more of a punch though. Actually the first run I did at WOT up a slight incline resulted in my hood flying up so this hack may result in a new hood lol.
Screen Shot 2017-02-15 at 8.35.55 PM.png (729.96 KiB) Viewed 888 times
http://shealabs.net
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 614 times
Been thanked: 254 times
United States of America
matthew1
Post by matthew1 » Wed Feb 15, 2017 6:47 pm
Outstanding, thanks Henry. This is a real "proof of concept".
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
henrysin44
Sweden
henrysin44
Post by henrysin44 » Wed Nov 15, 2017 5:48 pm
matthew1 wrote: ↑
Thank you! With my 855T manual swapped i could spin tire accelerating in 1st without trying :D , thought it was because of the manual transmission but decided to swap ECUs with a un-modified M4.3 ECU I have laying around and couldn't get the tires to spin so I'm thinking this mod might actually do something, not much but something.
P.S: Having or not having a voltage regulator has no effect so I wouldn't bother adding it.
http://shealabs.net
