We need 1 FR strut assembly for a 2001 S60 FWD for a Volvo owner in need. New or working/used condition. He drives his wife 60 miles 3x/week for cancer treatment. I'll pay your shipping costs.
Did you know? 🤔
2002 V40 (Nordic) Red.
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
New Zealand
difflock54
Re: 2002 V40 (Nordic) Red.
Post by difflock54 » Sun Jan 03, 2016 1:22 am
2-01-2016 Mileage 110,680km's.
Top radiator hose (Gates-with Volvo labelling and part No' still visible) has started weeping coolant under pressure due to hairline fracture of the moulded 3-way junction design of the hose which forms the connection point for the overflow return hose to the coolant reservoir.
Fitted new Febi-Bilstein replacement hose and topped up coolant after burping the system of airlocks.
The rubber sections of the old top hose all looked in good condition. The failure (weak part) was clearly the moulded polyurethane section. Literally crumbled when lightly poked with a small screwdriver.
difflock54
New Zealand
difflock54
Post by difflock54 » Tue Jul 25, 2017 9:27 pm
26-07-2017 Mileage currently at 116,240 km's.
Oil change and new filter.
Chief Cherokee semi synthetic 10W-30.
Filter Purolator L15315
difflock54
New Zealand
difflock54
Post by difflock54 » Tue Jan 09, 2018 3:15 am
4-01-2018
Right side rear door window regulator / motor unit packed up suddenly. Could not get window to wind up.
Terrible whining noise and grinding.
Removed inside trim etc to find the cables were mangled around the regulator motor spool and frayed.
Obtained a good, working complete used regulator/motor unit salvaged from a 2000 V40 being identical for $55.00 NZ.
Easy to refit and all working again smoothly.
difflock54
New Zealand
difflock54
Post by difflock54 » Wed Feb 14, 2018 6:32 pm
15-02-2018 Mileage 117,636 km's.
Front disc brake pads require renewal. Discs are in good condition.
Fitted TRW GDB 1313 COTEC pads obtained from Repco Auto Parts. Cost $53.39 NZ.
Easy job, no hastles.
Used a 'G' clamp to retract calipers.
