2003 S80 ETM
jimmy57
- Been thanked: 322 times
Install and turn ignition on for 40 or so seconds and you will hear the throttle be manipulated to open-close-open-close. That is the calibration and is all that is required.
jimmy57
Yes. The unit on your car is a motor and two position potentiometers. The ECM only needs to know the signals from both pots at their end points to know how to operate the throttle.
Hi Jimmy57,
Does same apply to 05 S80?
Local Vovlo shop just diagnosed bad ETM - need to replace it. I said I would do it myself...they said it would need s/w programming to be used.
I did the PVC service last spring, cleaned the TB while I was at it...I fell like I could remove/replace w/ new unit....but the programming has me concerned.
I appreciate the help.
Thanks
Peter
Thanks
Peter
precopster
- Year and Model: Lots
- Been thanked: 128 times
There IS NO software part number for a Bosch throttle reload. Dealers are using previous info of ETM (Magnetti Marelli) to extract dollars from unsuspecting customers. When they realise there was no software download they still charge for it to appear knowledgeable.
- 4473 Views
Last post by ajwsurfer
- 4928 Views
Last post by antonevane
- 15 Replies
- 6735 Views
- 4697 Views
Last post by firstv70volvo
- 2055 Views
Last post by matthew1
