Did you know? 🤔
Installed Yitsbox VVIS Modification
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
jantt
Year and Model: C70 2000
Has thanked: 0
Denmark
jantt
Re: Installed Yitsbox VVIS Modification
Post by jantt » Tue Jun 14, 2016 10:57 am
ok so you don`t think my 1992 need it even if it works on Ben850`s 1993 ?
I will have the tool from ARD http://www.ardideas.com/ARD-Cam-Timing-Tool_p_146.html in a couple of days to set the cams.
razorx
Year and Model: 855 '96, 854 '93
Has thanked: 0
Been thanked: 0
razorx
Post by razorx » Tue Jun 14, 2016 11:03 am
@jantt: What is the serial number of your car?
jantt
Has thanked: 0
Denmark
jantt
Post by jantt » Tue Jun 14, 2016 11:05 am
YV1LS5506N2006993
razorx
Has thanked: 0
Been thanked: 0
razorx
Post by razorx » Tue Jun 14, 2016 11:20 am
Thanks. I think i have written down when Volvo changed the way the manifold is being controlled.
In the very first 20V's the solenoid that controls te VVIS manifold has been connected in a different way.
My circuit will work as expected when the vacuum line to the manifold and the vacuum cover are swapped.
jantt
Has thanked: 0
Denmark
jantt
Post by jantt » Tue Jun 14, 2016 11:26 am
ok thanks.
Then I am up for buying the swith and if you can tell me how I should connect the lines.
razorx
Has thanked: 0
Been thanked: 0
razorx
Post by razorx » Tue Jun 14, 2016 11:28 am
I found it in my old thread.
http://www.volvo850forum.nl/index.php/t ... 565.0.html
Google translate translates Dutch well.
Below sn 30699 lack power above 4100RPM
razorx
Has thanked: 0
Been thanked: 0
razorx
Post by razorx » Tue Jun 14, 2016 11:29 am
And above sn 30699 lack power below 4100RPM. ;)
jantt
Has thanked: 0
Denmark
jantt
Post by jantt » Tue Jun 14, 2016 11:39 am
ok so are you saying that the swith will not do any thing for me even if swap the vacuumlines ?
razorx
Has thanked: 0
Been thanked: 0
razorx
Post by razorx » Tue Jun 14, 2016 11:43 am
No the opposite:
The switch will work as expected when you swap the vacuum line to the manifold and te vacuum cap. ;)
jantt
Has thanked: 0
Denmark
jantt
Post by jantt » Tue Jun 14, 2016 11:55 am
Ok then I am still up for buying.
Will you send message to us who is written up if you make it again ?
I have already done this to my car and your switch could be the last thing to do :
1. Sanded down plastic on trottlehouse disc.
2. ultracleaned injectors.
3. KN filter
4. 76 mm intake hose to airfilter and blocked preheating from exhurst.
5. new raceheader, new cat and 2,5" simons exhurst.
that gave me 192 bhp and 255 Nm.
Since I have mounted two new racechips in ECU.
Got 0-60 times with app 7,03 - 6,70 - 6,55 - 6,83
Will now set cam 3 degres advance that should give better acc.
